Blown tranny pumps do not leak, torque convertor seals do.
Here's what you do ;
With a can of engine cleaner, crawl under your vehicle and liberally soak the entire undercarriage where there is oil, hose it down and let it dry off, now start your vehicle, leave it in park and let it fuully warm up.
Now crawl under and check for fluid leakage, if none is found, shift the tranny from park to treverse and so on until you hit low, wait 5 seconds between each shift, do this twice, crawl back under and again check for leaks, if none are found carefully check the dipstick tube for wetness.
If everything is still dry, drive the vehicle around the block once, keep doing this until the leak shows up.
Possible points of leakage ;
Tail shaft (driveshaft)seal, easy fix, remove driveshaft and replace seal.
Transmission pan seal, easy fix, drop pan, replace filter and reinstall pan with new gasket.
Fluid found dripping from bellhousing, leaking torque convertor seal, difficult fix, transmission is removed, torque convertor is removed, seal is replaced, torque convertor and tranny reinstalled.
OIl is being forced out of either the breather tube (found on top of tranny) or the dipstick tube, difficult to repair, this indicates excessive pressure, a plugged breather tube or a overfilled tranny, drive vehicle to a repair shop.
