Throttle isn't stuck, we WD-40ed the hell out of it.Originally posted by: EyeMWing
HAHAHAHAHA. That's just HILLARIOUS mental imagery. Sounds like the throttle is stuck, but I'm no expert.
Eli's usually right. There should be an adjustment screw on the throttle body somewhere for the idle, but those are preset at the factory and shouldn't be messed with usually.Originally posted by: Eli
There's probably something amiss in the vacuum system.
That's the problem. Do _not_ adjust the idle until this is fixed or the car will not idle at all once that has been fixed.Originally posted by: MonkeyDriveExpress
The car's been sitting around for quite a while (don't know exactly how long), so I wouldn't doubt any possible non-outlandish solution right now.
EDIT: The car's also getting WAY too much gas, it's getting 6mpg (suburban driving) and you can smell some gas in the exhaust.
"Oil container"? You should not be allowed anywhere near an engine. To begin with, there's no such thing as an "oil container". There is a fill spout, a filter, and the engine sump. The idle adjustment will be on the throttle body.Originally posted by: zimu
google it. i know there is this switch you can simply turn under the hood which adjusts the fuel goign into the engine during idling. depends on the make of the car though- as to its precise location. its easy to do, can be done by yourself. check near your oil container.
If you're not mechanically inclined it's not something to really get into. In a modern car there are vacuum lines running all over the place, and unless it's a really obvious failure it can take a lot of time to diagnose. Plus there is the potential for vacuum leaks on parts like the throttle body and removing and re-sealing it is not for someone who is new at repairs.Originally posted by: MonkeyDriveExpress
Hmm, how hard is it to troubleshoot a vacuum leak? I don't have any specialized tools or a lift (or even a garage to put the thing in), should I just get someone to do it for me?
Start the engine, & listen for a hissing sound. If you hear hissing, wiggle the ends of any hoses near the source of the sound to see if they're loose...Originally posted by: MonkeyDriveExpress
