Originally posted by: OBW96
never mix
Why would you? Just change your oil...or if you're topping it off, buy the same weight, and preferbly the same brand/kind (not as important as weight...just something I like to do)
never mix
never mix
never mix
never mix
well, I use 5w-30 for the summer and 10w-30 for the winter. when I do the oil change, I got some left. so I just mix them up in one bottle.
never mix
Originally posted by: KEV1N
Just throw some diesel fuel in there to stabilize it!!
never mix
Do you have that backwards? 10w30 for summer and 5w30 for winter is better. But I run 10w30 year round.
Originally posted by: Eli
It isn't going to hurt anything in a pinch. Much better to mix the oils than to run low or whatnot.
Originally posted by: Sheepathon
Keep the 5w30 in the hondas and the 10w30 in the toyotas (assuming you have a japanese car). Unless you live in a place like socal, where the weather is so perfect that it doesn't matter if you put 1030 into a honda.
just bought a bottle of 5 quarts 10w-30. i think i overfilled by .5 quart. does it matter?
