YACT: 98 Explorer Catalytic Converter Efficiency Code
DeadByDawn
2,349
I own a 98 ford explorer, V8, All wheel drive, 75k miles. About a year ago the check engine light came on, took it into the dealership and they said that the catalytic converter was shot. So I had it replaced, and since my car had less than 80k miles on it they did the work for free. Got it home and it had a pretty good miss to the idle. I replaced the spark plugs and wires, and that took care of the miss. Then the check engine light came on again. It was giving me the following code:
P0430
Catalyst System Efficiency Below Threshold (Bank 2)
So the guy at autozone told me that meant that the 02 sensor on the passenger side was bad in front of the converter, so I bought a new one and replaced it. Cleared the code, and it comes back on about 100 miles later. The car idles and drives fine, fuel efficiency is about where I would expect it to be. What would be the next thing you would look at replacing? They guy at autozone said to replace the EGR valve. I could send it back to the dealer that changed out the catalytic converter, but they charge an arm and a leg, are far away, and I really don't want to deal with them if I could fix it myself.
RagingBITCH
17,618
How does Ford suck? Because the guy at autozone probably doesn't know what he was talking about if it's still the same code as before? That the miss you had was probably because you should have done a tune-up a long time ago?
woowoo
2,092
You go from the dealer to autozone?
Where is the "Trusted local mechanic"
Find him, he will help you........
Your Ford will be DeadByDusk, shall I go into one of my repair rants ?
Quixfire
6,892
ISSUE:
Some 1998 Explorer/Mountaineer vehicles equipped with the 5.0L engine may exhibit a malfunction indicator lamp (MIL) on with diagnostic trouble code(s) P0420 (Catalyst System Efficiency Below Threshold - Bank 1) and/or P0430 (Catalyst System Efficiency Below Threshold - Bank 2).
ACTION:
To service, reprogram the powertrain control module (PCM) to the latest calibration using WDS release B28.3 or higher. Replacement of catalysts is no longer necessary to address the most common causes of this condition.
All you need to do is have the dealer reprogram your PCM to solve the problem. Never ever listen to Autozone for driveability daignosis.
Damn you Quix, I wanted to rant.
THAT WAS A WAAAAAY TO SIMPLE A ANSWER
PingSpike
21,766
615
Originally posted by: Quixfire
ISSUE:
ACTION:
So basically he needs to reflash in Explorer with the latest available bios.
Quixfire
6,892
I'm sorry Roger I thought he was asking for some help with his problem. I could remove my answer until later if you would like.
Quix, you must start behaving like Scotty on the "old" Enterprise, when people ask you for something, tell them it will take 25 hours to accomplish, then do it in 1 hour, in this case, you should have at least typed two paragraphs of techno babble that no one including I could understand,m then post a simple explanation at a later date. 😉
NutBucket
27,181
649
Hey, that sounds like my job!😀
Quixfire
6,892
I though that was your trademark. 😉
I will try tyo do better in future posts.
DeadByDawn
2,349
OMG Quix YOU ARE THE MAN!!!
Where did you find that info if I may ask?
Thank you thank you thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DeadByDawn
2,349
I take it you don't like fords LOL. In all seriousness I have had more problems with this vehicle than any other that I have owned.
Quixfire
6,892
As Roger stated I am a Ford tech, slightly retired, and I have access to a Ford service knowledge base.
Ornery
17
The powers that be must be prejudiced against Ford, or Quixfire would be an Ultra-Elite member by now!
Jebus, I have got to get new glasses, when I read your statement quix, I first read it as ;
As Roger stated I am a Ford tech, slightly retarded, and I have access to a Ford service knowledge base.
Quixfire
6,892
Thanks Roger, that's the funniest thing I read all day. In fact I'm still laughing as I type this.
