YACT: '97 Mazda Protege
vegetation
4,270
From my experience, cars without tachs usually have the lowest base engine in them. That often means an engine that makes most of its power in the midband range with a rapid decline in power approaching maximum revs.
Ronstang
12,466
13
You should not need a tach to know when to shift. If you do, you don't know how to drive a stick or understand the mechanics anyway. The only time you NEED a tach is in a race car.
orakle
1,122
Originally posted by: Cattlegod
Originally posted by: Stunt
You don't need a tach.
(approximate)
start = first
15-25 = second
25-45 = third
45-60 = fourth
60+ = fifth
yep, that is if you are going a bit faster. if you want better mpg just shift into
0-10 = first
10-20 = second
20-30 = third
30-40 = fourth
40+ = fifth
I have an '03 mazdaspeed protege and that is what i usually use.
Thanks.. I was actually wondering what shift ranges other people were using.. I usually do it approximately like this:
0-20 km/h (0-12mph) = first
20-50 km/h (12-30mph) = second
50-70 km/h (30-42mph) = third
70-100 km/h (42-60mph) = fourth
100 km/h+ (60mph+) = fifth
Gas is up to around $1.20 cdn/L (almost $4 usd/gal) where I live, so I'm trying to drive softer and I'm going to start shifting earlier if it means saving a few bucks.
Raduque
13,141
138
Everybody else gave good advice on shifting, so I'll throw in on the stereo: It's probably a proprietary plug for a factory CD changer. If they still make them, just get another casette adapter, or maybe a new HU.
Stunt
9,717
(approximate)
start = first
15-25 = second
25-45 = third
45-60 = fourth
60+ = fifth
0-10 = first
10-20 = second
20-30 = third
30-40 = fourth
40+ = fifth
You are Canadian!?
Here I am wasting all my time trying to convert to mph for you...
I was thinking where i typically shift in km and trying to round to mph...
hehe :D
Lonyo
21,939
(approximate)
start = first
15-25 = second
25-45 = third
45-60 = fourth
60+ = fifth
0-10 = first
10-20 = second
20-30 = third
30-40 = fourth
40+ = fifth
I do 10 (to 2nd)/20(to 3rd etc)/30/40 shifts usually.
If I'm on an easy run I won't downshift if I don't need to (like down a hill or on the flat), so sometimes I'm 25mph in 4th, or 30 in 5th.
orakle
1,122
You are Canadian!?
hehe :D
Funny how people try and accomodate each other... I often find myself speaking French to another anglophone just because neither of us realize what each other's first language is.
thedarkwolf
8,993
105
Did the higherend Proteges have tacs? If so you might just be able to swap out the whole gauge cluster for one with a tac. The wiring and crap will probably already be there but you would have to ask somebody that knows proteges.
CraigRT
31,440
I don't suggest doing this often, but rev it high sometime as you are accelerating and see if you can find a fuel cutoff... That should help you identify how far away you are from redline when you are accelerating hard.
ASK THE COMMUNITY
