YACT: 1999 Kia Sportage hazard lights came on by themselves, won't turn off
Joemonkey
8,859
4
So my wife just went outside and came back in saying "my hazards are on"
she got in the car, pressed the hazard light button, and the hazard lights stayed on but blinked a little bit slower. Pushed it again to turn them off, they stayed on but picked up in speed a little bit
When the key is in the "On" or "Acc" position the lights stay off and function normally with the button
When the car is started the lights stay off and function normally with the button
I've tried pulling the fuse to conserve battery power, but the manual is bullsh!t as far as fuse locations... it says hazards are a 15A fuse in a certian location, but that location doesn't exist, and i've tried pulling all the 15A fuses in the kick panel and the hazards stay on.
It's been raining pretty heavily and we had some close lightning if that makes a difference, but i doubt it does since the lighting wasn't THAT close and my car (1999 VW Jetta) is right next to hers and is fine.
Kia forums are few and far between on the 'net, and the searching for info is slow going. Anyone have any ideas?
Lotheron
2,188
4
That is the funniest thing I have ever heard... I hope someone has an answer LOL
Joemonkey
8,859
4
wife just told me she set the alarm, then unlocked the doors and something popped really loud
so yeah i just went out in the pouring rain and disconnected the battery...
Joemonkey
8,859
4
Well i found this page, looks like her turn signals and hazards have been recalled but no letters were sent... check out EA00-018 and PE00-004
Viperoni
11,084
It's about time everybody had a well made car! :D
Sorry, I just had to :)
GL with it, hopefully it's nothing big, and even better, it's covered under a warranty.
Kegger
almost sounds like that loud pop you heard was a short in the flasher assembly and instead of blowing apart and disconnecting it sort of like welded itself together making the current keep flowing thru it instead of making a disconnect
GalvanizedYankee
6,986
Is the hazard button integral with the ignition switch ? If it is, it might be bad. Changing out an ignition switch can be a pain, as they are installed with tamper proof screws.
A stuck relay would most likely leave them on all the time.
You have to register but autozone.com might have something to offer. Look up your car there.
VTboy
Banned
Oct 13, 2003
383
I think your battery might be near dead. My car does the exact same thing when the battery is dead. It is the alarm doing it when the battery is dead.
WinkOsmosis
Banned
Sep 18, 2002
13,990
That makes sense. Flash lights when the battery is near dying!
Black88GTA
3,430
It's because the Kia itself is a hazard, to yourself and others. Standard feature on all Kias.
:p
VTboy
Banned
Oct 13, 2003
383
This happens because the alarm is confused it thinks someone is trying to tamper with the alarm because the power keeps fluxuating so it makes the alarm go off, only there is not enough power to fully make the alarm go off. I have driven 2 different cars and both do the same thing when the battery is low/dead.
