Nocturnal
I have a 1993 Honda Civic Si bone stock. The only modifications are done to the suspension.
My car is now overheating. Overheating as in the temp gauge will go all the way to the top of the line if I am idling. If I drive it?s ok, and it goes down to where it normally is.
Someone mentioned it may be my thermostat. I honestly don?t know how to change that out nor do I know where to get a new one from.
Also I just checked my engine out and it looks like there is water leaking from a hose connected to the bottom of the intake manifold near the injectors.
Any advice?
Any advice?
