Originally posted by: Quixfire
7/8" wrench, Special O2 socket, or a good pair of Knex pliers.
Originally posted by: MogulMonster
Ratcheting wrench should do the trick. I love those things, and have almost given up on sockets since starting to use them. They are a little pricey, though.
I spelled it wrong, it's Knipex Cobra Plier . I apologize for my bad spelling.Originally posted by: rpbri2886
I have been trying the 7/8" wrench all morning, but i cant get enough leverage.
What are knex pliers?
-Brian
Originally posted by: Soybomb
Use some penetrating lube, maybe even take a torch to it and heat it up before you try and loosen it. Find a way to get a socket on it and it will be alot easier, its probably in there quite firmly. Use some anti-sieze on your new one...
The problem is I have no time to go anywhere and get anything.....
Can i drive the car without an 02 sensor?
The wires are cut that go to it, so that i could get the socket on.
Originally posted by: LAUST
HEAT is your friend... oh and the PB blaster mentioned rocks too.
I should know, I have 5 of those dazm things. 2 up, 2 down and 1 Wideband (w00t to wideband 😉 )
why a wideband with a supercharger? I can see it with a turbo but at: Best Time: 14.98 / 89MPH @ 5800ftI don't know if all that is necessary. [most widebands are expensive and a waste for most]![]()
as far as: Yes that was a Z28 getting smoked, notice his MPH you n00bs that don't know better 😉 [his mph being almost 94mph] sounds like he spun too much off the line. More than likely a very inexperienced driver.
but yeah heat and pb blaster is cool.
