YACarT: heat sheilds, and how improtant are they?
BriGy86
4,537
1995 ford taurus GL
heat sheilds
other side of heat sheilds
the bigger one fell off this morning, i heard a clanging when i went over some bumps, after a perticular bump i hear something dragging
so i pulled over saw it hanging and just decided to pull it off, since it wont seem to do any good just hanging there
i had the same type of incident with the little one about a year ago
both were pulled from the same general area in the middle of the car just behind the front wheels
is this something i should worry about?
ironcrotch
7,749
hahaa your car is fallin apart man, literally. should be fine without them, should. YMMV.
thedarkwolf
9,037
132
looks like the heatsheild on the pipe leading to the catalytic converter and the one that goes under the cat. You don't really need them but I wouldn't park on dry grass with the car running. The cat can get pretty damn hot.
BriGy86
4,537
thanks for the responses, when my car savy friend gets home ill raise the car a bit and try to get pics of the underside if need be
SnipeMasterJ13
1,005
Good man. Understands the importance of pics. Make sure to take some of hot chicks (obviously) if you see them.
BriGy86
4,537
its only got 89,000 miles on it too
also- hasn't been washed since the day i got it june 2004
iamwiz82
30,772
13
That's probably the issue. Lots of salt and no cleaning leads to rust.
BriGy86
4,537
yeah i have to get around to it:eek:
IamElectro
1,470
If a car company put heatshield on a car they put them there for a reason. I doubt they would spend money making and installing a part that was not needed.
I would try and put them back on.
BriGy86
4,537
you should know that there are no hot girls in our school
well maybe on the architecture floor, but they are very elusive
captains
4,065
hahahahahah
SnipeMasterJ13
1,005
Oh, and I just thought of something else. With that substantial weight reduction, your 1/4 mile times will be better next time you bring that thing to the track.
radioouman
8,632
They are there for a reason. Probably to prevent the hot exhaust from damaging a component under extreme driving. (Towing uphill with the A/C on....)
BriGy86
4,537
from how they were hanging i think they were more in a position to prevent heat going down
like the dry grass thing that was mentioned, but ill take a look at it more with my friend
captains
4,065
hahahaha
