Ya, another Radeon LE question.
BrainSalad
Banned
Mar 3, 2001
266
I was trying to figure out if you can use the same Regular Radeon Drivers for the LE version as well? If the answer is yes, why do the same drivers disable HyperZ if they don't disable it when using the drivers on a regular Radeon? Do the drivers detect that it's an LE?
Thanks
merlocka
2,832
Yes, same drivers.
Yes, I assume the Radeon LE has a different BIOS which is how it's identified.
