Y A HL2help! T
Tiamat
14,068
http://pics.bbzzdd.com/users/j...a/d1_canals_030000.jpg
I am in the room that there are at least 20 Explosive barrels and the second you jump into it, 6-10 of those razor flying robots attack you.
Not sure where to go next. I cant seem to jump into the ventilation shaft that those flying things came from. Ive been to the room to "my left" as shown in the picture, but there was nothing I could do there except see a potential "next area".
I couldnt find anything to do in the basement of this room either...
Thanks much!
Crusty
12,684
This question has been asked soooooo many times :p
Go into the other room and fall down on the pipes. There is a valve that you turn there.
NYHoustonman
2,642
There's a valve that u have to open in that area "to your left", as far as I can remember. It'll fill the water up so you can get into that passage below you. You have to jump onto some pipes from the top, and make ur way down.
sswingle
7,183
45
Do a search. You are like, the 50th person to have trouble here.
Ok, i'll be slightly helpful. Go up ladder, go to another room with more pipes, jump down a couple pipes and there is a wheel you can turn that fills the place up with water, so you can swim to the top.
Tiamat
14,068
Im sorry heeh! I read the other posts about the valve, but i didnt think i was "that" far into the game. Ill search harder in that "room to the left"
Thanks guys for the insanely fast response!
screw3d
6,906
I got stuck at this place for a while too but figured it out eventually :)
I actually grabbed ALL the barrels and squeezed it through the entrance of the ladder :eek:
Crusty
12,684
Hahaha I did that too! That was the first time I was like "wow" these physics rule. The first barrel went by accident just hit and it rolled. I turned away and heard a splash, went down and saw a barrel! SO I had to put the rest of them down!
sparkyclarky
2,389
I've got you beat. At first I didn't see that valve in the next room. So, the water level in the pit was low. So, I put all of the barrels down there, then spent 15 minutes building a ramp to get into that pipe (which was a fair bit above the low water level). I got into the pipe, went over to the other room, then tried to figure out wtf I was supposed to do. When I realized that there was no way in hell that I could make that jump, I scouted around and finally saw the valve. Man was I pissed that I had just wasted 45 minutes on that section.
screw3d
6,906
:Q
Daym!!
