FrankRamiro
HiGuys;I'm trying to figure out this problem with the mouth in Xbmc,i installed from this codes and when i try to use the mouth inside the XBMC it just moves around and i seem not have control over it,it floats around,in Xubuntu 1310 is ok
sudo apt-get install python-software-properties pkg-config
sudo apt-get install software-properties-common
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install xbmc
sudo apt-get update
