Question XPG SX8200 Pro 2TB 3D NAND NVMe Gen3x4 PCIe M.2 2280 Solid State Drive R/W 3500/3000MB/s SSD to Samsung 990 Pro SSD will I see a difference ?
Tech Junky
3,825
1,342
Well gen3 drives top out ~3GB/s and Gen4 are closer to 8GB/a so, 2-2.5X faster boot / loads.
Windows will still load in about 10 seconds and Games will probably load in the same time if you're not upgrading the GPU to something with faster GDDR on it.
Normal tasks though won't be noticeable.
pcslookout
11,959
156
Ok so not even intense tasks will be noticeable thanks.
Tech Junky
3,825
1,342
Well, it depends on the task. If you're doing a lot of R/W it will make a difference like transactional DB's would make use of the faster interface / bandwidth.
I've got a handful of different NVME drives sitting around and there are some nuances between them that show their face when doing certain things and only then. Some have a Phison controller on them, others a SanDisk controller, some proprietary options as well.
If I'm doing an extended copy of say 100GB of data the Phison's will drop off after the DRAM is exhausted. The fastest one though seems to be the SN770 but, the key to making it faster is not to do a bulk dump to the drive but drop several separate moves to it.
So, there's more in play than meets the eye on the cover of my statements above if you're doing certain things it might be the best idea to use the 990 as the OS / apps might benefit from the higher bandwidth. I would simply clone it with clonezilla and pop it into the primary position and see how it feels compared to the XPG. If it feels snappier then leave it there and wipe the XPG and give it a new UUID so it doesn't conflict with the 990 and pop it back in for additional storage.
