joshcloud9
I just got an XP3200 (eBay cheap deal! - $95 🙂 to upgrade my XP2400 on a Gigabyte 7N400-L
With the XP2400 the CPU temp was around 40c
upon booting up I went into the BIOS and the reading was 60c and climbing...I almost has a baby!
I took the whole MB out and cleaned all surfaces and did a super micro install of the HSF etc...
I let it boot to Windows and was releieved to see Speedfan showing 44c - perfectly acceptable 4c temp rise I'm thinking...
Then I go into Speedfan setup and see that another sensor (Diode3) has been detected and was reading 60c!
See the pic here: Speedfan/SiSoft Sandra insert
SiSoft Sandra see's the old temp as a Power/Aux temp?
My question is does the XP3200 have two sensors or what am I seeing here...
Thx,
Confused...
Thx,
Confused...
