xp3000 Locked or not?
yokomo
hey guys I have done the pencil trick on many cpus already but I have a enw xp3000 333mhz and I want to over clock it are these usually locked because as soon as I try and set the multiplyier in the bios it will not post I have to reset it and then move the buss speed back to 166 so do I have to unlock this bad oscar to push it and can I do the pencil trick or is this one that needs that goop for window defrosters?
Also any links to where I can get that stuff if I need it would be great. Thanks in advance guys and gals..
man that totally blows because it will now even attempt to boot with it at 200mhz... man I got the same performance out of my 2400 bumped up to a 2600. Oh well should have done my home work I guess...
Did you increase the vcore (voltage to cpu)?
Also the multi (locked) is set pretty high on those - 13X see here. That w/b a 2.6ghz CPU, not likely w/o serious cooling and high vcore.
If your mobo has an AGP/PCI lock, try FSB of 185mhz. That w/b 2.4ghz, not shabby!
Fern
