Originally posted by: mikecel79
Don't mean to hijack this thread but I started monitoring the temp for the first time on my 2.6 P4C. I was shocked when I saw it running between 67 - 71 degrees! I'm running two copies of f@h on here 24/7. When I shut them down my idle temps usually drop down to around 41 - 43 degrees. Is thi normal for a P4C at 100% load all the time.
Edit: Left out some info. Gigabyte GA-8IK1100, stock HSF, and according to mbm5 the case temps around around 25 degrees.
Yep...Running the United Devices client here and I had a Palomino XP2000+ that occasionally would hit 72C if the filters weren't very clean. That was using a Thermalright AX-7 with a 46CFM fan.
Since then I have solved (for myself) a few issues I have seen in the Cases and cooling forum many times.
My Barton 2500+ (@2x198FSB)I am using right now is running 24C case and 43-44C CPU @ 1.775V (100% load)(48-49 if I 7V my CPU fan and 3 of my case fans) I use a Thermalright 800U with a Panaflo U1A (46CFM) Smart Fan II will drop another 3-4C, but sounds like a hair dryer.
I don't use case filters anymore because of flow reduction and as of a few weeks ago I am lapping all my heatsinks to 2000 grit then polishing the base with metal polish. The first PC I tried this on CPU temps dropped by 5C.
Unless The 71C temp you posted is the actual diode reading You could burn that puppy up! A good HS/fan combo will bring that temp down at least 10C.
