Gigabyte Board (latest firmware & supports the new processor) that had an XP1700+ Just got an XP2100, slapped it in and it will post and when the system is very cold, like turned off overnight, I can even get to my desktop in the morning but locks up quickly. Usually after a reboot or two I can't even get to the windows splash screen before it reboots on its own. All connections on the board are tight, cards reseated just to be sure and all power connectors are firm. I can put the 1700 back in there and all is well. The 2100 does post as that (Athlon XP2100). I am thinking voltage change but wanted some advice before I go get the motherboard PDF and try to find the jumpers. Can't change the voltage in software. Here is my BIOS hardware monitor information.
VCore - Normal ( this has various settings +7.5, +5.0 and +10 changing this does not change the other data numbers and has no effect on the problem)
Temp is good or at least it seems to be. This chip runs much cooler than the 1700 even after sitting there for 10 minutes.
CPU Temp---------------58/136
System Temp-----------28/82
Vcore---------------------1.728
VTT-----------------------+1.216
+3.300V-----------------+ 3.248V
+5.000V-----------------+4.838V
+12.000V---------------+11.840
5VSB---------------------+5.053
The +X.XXX numbers seem to fluctuate but not much. Slight changes as you sit and watch it. Most of that is greek to me. Anyway, I am not uncomfortabe with my case off. More of a network guy but got an A+ so fiddling is not a problem. Case cover pretty much stays off but Processors are not my gig. Is it the Vcore I need to change? What would it need to be for a XP2100 on a KT266 board with DDR PC-2100 RAM (512)? Or did I just perhaps get a bad chip. That would piss me off but I can exchange it if I do it in the next 10 days or so. Any help would be greatly appreciated or any other information I need to give, lemme know. TIA
