XP1600+ power supply? is 250 enough?
6TNINE
Banned
Oct 6, 2000
579
I am looking at cheap generic cases found on pricewatch and they come w/ 250 or 300 watt generic power supplies. are these gonna be good enough. gonna run a ecs k75sa w/ xp1600 and 512 megs crucial pc2100 ddr. visiontek g-force 2 gts. any recommended cases??? i only wanna spend about 40 shipped. thanks
69
jhites
1,854
Here is a link for recommended Athlon Power Supplies:
AMD PS
ENLIGHT EN-72370X3C4 MEDIUM ATX TOWER CASE with 300Watts Power Supply is a good case in that price range. May be more around $50-55 but will be good for your setup and you would not have to upgrade later as your system changes.
The extra $15 will save you $50+ later. IMHO!
Case quality is much more important to the system than many realize.
6TNINE
Banned
Oct 6, 2000
579
yeah, but there will be no upgrading. its a computer i'm building for my aunt, there cpu right now is a 486, so they wont be upgrading for a while. lol. anyway, i need something for about 40 bux max. any suggestions????
TallBill
46,017
62
hmmm.. i had a generic 300 watt with my xp1600.. and i got random freezes.. put in an antec 300w that i had, and everything was gravy!
ku
1,309
It really depends on the power supply. Good 250w power supplies is adequate for certain systems around that range. Bad ones aren't. There is no real way of finding out unless you try it, but I would recommend that you not try it. If anything, get 300w and try to get it from a brand name company.
ChrisIsBored
3,400
If she's upgrading from a 486, why even bother with an XP 1600+? That's way more power than she's used to, and much more expense than necessary.
Pick her up a 800 Duron and motherboard from the KT133A era... some cheap PC-100 RAM and that'll save you some cash...
She's not a gamer apparently, or she would have upgraded a long time ago...
hunterxx
For a basic computer that will be functional you may be better off to buy a system from a reputable online dealer. I picked up an Athlon 1GHz, 256 MB RAM, 30 GB HDD, 810 LMR MB, everything but a monitor for under $400 shipped.
At the time I couldn't build one that cheap. Not a gamer by any means but good for general apps.
