Thanks for the reply guys, I always follow the suggested procedure from the AS5 website for the proper amount and instalation. I got a Panaflo with the xp120 and even have it set it running to the max. I have a 120 size fan blowing at the heatsing\k area about four six inches away.
Algere thanks for the linky on lapping. You know I have tried four different brands of heatsinks for this system and I have never achieved below 45 degrees temp. I had high hopes for the xp120 but I guess it does not work for everyone. I am about to go back and set it up again for my water cooling and hope to achieve the desired temps, right now.
Just got done setting up the water cooling, 255 x 10, 200 fsb at 1.61 vcore idling at 42-45 running prime 95 and temps at 60-62 tops. Will run it for at least 8 hrs just to be sure everything is back the way it should be. I think this 13nm 939 is running hotter than my Prescott. I had it set up similar, the only difference is the water block, at 1.6 it was idling at 40 and 42 at the most while under load at 55 and 58 at the most. Only problem is I tried to get more out of it and I think I managed to kill my p4c800e dlx.
