XP Winsock Problem?! (error 10061)
ColinZeal
I Have a BIG Problem in XP..
I can´t somehow connect to certain things..
I run/have:
XP Pro.
Duron, ABIT KT7. 3Com NIC from 1996.
10mbit LAN to Internet.
I run ICQ, it works. I can check my mail. No problem. Surfing? no problem. Direct Connect?! Sure.
But these following things don´t work:
(All of the below except for BattleCom works under WinME without a problem. Haven´t tried it there)
Quicktime:
I Haven´t been able to connect to their server to install the player.
Ever. With Or Without Proxy (I´m supposed to run without)
Been trying for the last four weeks now.
NFS 5 Porsche:
Cant reach an IP-Adress for a session
The same seems to go for All games on the net. From Internet Checkers to Quake3!!
Audiogalaxy:
When i try to start the satellite i get the message:
"Connect to local host failed quickly with error 10061."
Then it suggest i disable my firewall.
I dont run a firewall!!
Neither ZoneAlarm nor XP´s internal.
Battlecom:
Can´t host a session:
"Battlecom could not find a server at the specified address."
When i press F1 for "help" it says:
"This error occurs when you are attempting to join a session using the TCP/IP protocol. It means that the client is unable to find a session at the address you have specified.
Re-check the address you have entered in the connection box and make corrections if necessary. If the address you entered is correct then it is possible that the server or session is not running or is full. Try the connection again later."
But i tried to HOST?!?!
And of course I can´t join either!!
What i´ve tried:
1) I tried installing another NIC (Intel 10/100) but the same problem was still there...
I have a "3Com 3C900COMBO-based Ethernet Adapter (Generic)" (10mbit from 1996). Tried latest drivers too. Oct-28.
2) Looking for a clue for the "error 10061" i get from starting audiogalaxy..
10061 is an errornumber for "WSAECONNREFUSED"
MSDN Says:
"If a Win32 Winsock clients issues a connect() call over TCP/IP protocol for a server and the server is not listening on the specified port, connect() returns SOCKET_ERROR and WSAGetLastError() returns error WSAECONNREFUSED(10061). However, the IPX/SPX implementation of Windows sockets on the Windows NT platform returns error WSAENETUNREACH for the same scenario."
It seems like i´m trying to connect to things from the wrong port?!? Am I right or Totally Wrong?!?!
HELP!! HOW can I Fix this?!?!
Poontos
2,799
You running the latest version of XP? Pro or Home? Retail copy?
Downloaded all the updates from MS WindowsUpdate?
Searched the MSKB, you mentioned MSDN... try the MSKB.
Do your games require IPX/SPX, if so, is installed?
ColinZeal
Thanks for the help. I noticed that ZoneAlarm blocked part of explorer.exe..
ZA which i haven´t run since XP´s boot locked up with it..
that was 4 weeks ago..
Anyway, problem solved!
