XP & WindowBlinds problem?
bchalker
Maybe because it is beta, but after applying any of the skins offered by WindowBlinds, I had "invisible" menus appears after the entering Start>Programs. Basically, I would have no submenus.
Anyone else have this problem?
Windowsblinds still suxs, it's version 3 beta 7 but it still is slow buggy and can cause some major problems. I had it install for one day and unistalled it because even when a skin wasn't loaded it still caused problems.
After uninstall the problems went away and the speed came back.
why dont you wait. MS is coming out with downloadable (stable) themes. whats wrong with the older 9x color themes? all you would have to do is setup the wallpaper.
dont use betas on main system, you're asking for trouble.
I also used it for one day.
Although it worked perfectly on my system, it slowed it down noticeably even though it's a kick-ass system.
