- Feb 4, 2005
- 79
- 0
- 0
Decided to stop hijacking other people's threads...sorry ya'll if i jacked your thread in the past, we must have similar problems..
I'm getting number of problems that aren't that fatal but do get annoying. Here's the setup I've got running:
Asus A8V Deluxe, BIOS is the one that came with it...(update?)
Athlon 64 3000+ Winchester
Ati All in Wonder 9600 128MB
PQI Turbo series (gunmetal) 512 Mb ram
Seagate Barracuda 120gb SATA
NEC dbl layer DVD+-RW
Floppy drive
Antec Sonata case with stock power supply
Windows XP SP2
Here are the problems in order of Most annoying to Minor:
1. During windows desktop operation or any application, all of a sudden a blue screen with white letters flashes for about 0.2 seconds and then it restarts. I did a google search on this, and I believe the error message is something like this:
A problem has been detected and window has been shut
down to prevent damage to your computer. The problem
seems to be caused by the following file: cap256.sys
PAGE_FAULT_IN_NONPAGED_AREA
If this is the first time you've see this stop error screen, restart your
computer. If this screen appears again, follow these steps:
Check to make sure any new hardware of software is
properly installed. if this is a new installation ask your hardware or
software namfacturer for any windows updates you might need. If problems
continue, disable or remove any newly installed hardware or software
Disable BIOS memory option such as caching or shadowing, if you need
to use safe mode to remove or disable components restart your computer,
press F8 to select advanced startup options, and then select safe mode
STOP: 0x000000050 (OXF9CBC4AB, 0x00000000, OXF9CBC4AB, xxxxxxxx)
cap256.sys-address: F9CBC4AB base at F9CBA000 Date stamp nnnnnnnn
^^^^^^ <--- this is the failing module name
Note : If the failing instruction address is within the range of ntoskrnl.exe, the failing module is unreadable character.
________________________________
just that the specific addresses and stuff are different, but then again, i can't see it.
2. Many games I try installing either can't install or have problems in the game. The games that didn't install are FarCry, which had an error popup that wouldn't allow setup to continue. Then in Call of Duty, many times the game doesn't work when loading, sometimes with errors like "Brush does not have 6 sides" or "____: Children exceeded"...all this weird stuff.
3. I can't update the BIOS...the reason i want to is because I hope the new bios would be able to adapt to my memory better..after all i've also been getting memory error problems in windows...that say The memory can not be "read"...blablabla
I've ran the Memtest86 boot disk, and got over 100,000 errors i believe..and don't know what to do about that. lol
Please, any suggestions are greatly appreciated, i don't wanna believe I made a crap computer setup...cost me about $1k..sheesh
-Jonathan
Floppy drive
Windows XP SP2
-Jonathan
