Providing you used the System Restore function to make an image 1st, then shut off System Restore, AFAIK, yes in the future you should be able to re-activate System Restore and go back using that image.
If I remember right, there is one of the M$ warning windows that pops up when
you disable System Restore, indicating existing restore points will be lost!
I think that you will lose all your restore points if you disable System Restore in XP. I know that this happened when I disabled system restore in WinME.
