EDIT: FIXED.
I did everything and nothing worked. Then I thought the one thing I did not look at was the cable. I unplugged it at the NIC, and reinserted it. I then changed the port of the switch at the other end.
It fixed it. Not sure if it was a connection or a bad port, but did not want to play any more! SP2 had nothing to do with it!
This took a while to fix as I do not use the "bad' system that much.
Anyway, I added this note in case anyone else has tried everything!
I am sorry...I know better than that, but wondered if there was a generic issue. None of the above has helped.
My problem is this...
I have 3 systems running XP Pro SP2.
2 of them have onboard NIC's and are fine. ALL 3 systems see each other OK, but one of them, a P3-500 transfers VERY slowly...like a dial up modem! the two good systems are FAST.
The Slow system has a PCI Linksys LNE100 Tx Version 2.
Could it be that SP2 does not like the driver? Before SP2, all 3 systems talked to each other at 100 Meg and were very fast!
Originally posted by: JeffMD
yay.. im so glad you listed what hardware you were using so that it would be easy for us to help you troubleshoot your problems.
/esp
