I just used AutoStreamer to add SP1 to my XP disk. I did as the program said and burned the image but the computer won't boot from the CD as it says insert CD with correct something but if you insert the CD in a computer with windows installed it opens the XP splash screen asking what you want to do. What did I do wrong? I used the XP CD and the computer booted from it the first time and installed XP. I need this CD to work for my 250GB HD install this weekend for large CD support on windows install.
__________________
__________________
