I'm trying to get RH 7.2 to dual boot on a New Dell Inspiron 4100 that
came with XP over NTFS. I used PM7 to repartition since parted does not handle NTFS. After going through the install I can boot RH on using a boot floppy and XP boots fine. I then created boot sect and put this C:\ and then edited boot.ini to prompt for RH. Everything works except when I choose RH to boot from the system just puts an _ and hangs.
Booting RH from the floppy shows the following disk format.
/dev/hda
/dev/hda1 FAT
/dev/hda2 NTFS
/dev/hda3 Extended
/dev/hda5 ext2 /boot
/dev/hda6 ext2 /
/dev/hda7 linux-swap
/dev/hda4 FAT
Not sure what could be the problem, I created boosect.lnx using /dev/hda5
and after putting it on C: changed the attributes to +h +s.
I let RH automatically create the partitions it needed from free space and now when I start PM7 it says LBA and CHS values are different and askes me if I should fix it.
/dev/hda
/dev/hda1 FAT
/dev/hda2 NTFS
/dev/hda3 Extended
/dev/hda6 ext2 /
/dev/hda4 FAT
