XP Problems- Help
Kobe08
36
I got a HP scanner last week. I installed it- and went through the usuall stuff.... NOW, when I reboot, It always brings up the SYS.32 hidden files window. Sure, its easy to just exit out of it, but why would it be bringing up that window???? Thats a wierd thing to be popping up when you log on, isn't it? Thanks!
NogginBoink
5,322
The "sys.32 hidden files window?"
Check your Run key for a blank entry. HKLM\Software\Microsoft\Windows\Run.
