DasFox
Whenever I install something in the "Computer Management" - "Event Viewer" - "System" I get Event ID messages like this one below:
Generate Activation Context failed for C:\WINDOWS\system32\fdco1ins.dll. Reference error message: The referenced assembly is not installed on your system.
From what I have read these are called "Side by Side". The first one I had with the same type of message, but a different ID number I found out I needed to install the Visual C++ 2005 Runtime Libraries Beta2 x64, vcredist_x64.exe
Well that took care of one ID and from what I thought was suppose to take care of all Side by Side warnings, but didn't, I'm now trying to figure if anyone knows about a, Side by Side" Event ID 59", in XP Pro x64?
THANKS
THANKS
