XP Pro Virtual Memory/PageFiles
imported_IrvinJ
12
2GB Cosair pc3200 C2, four sticks all matched, plenty of HD space on second HD. What should be my PageFile size? and what is the formula for figuring it?
stash
5,468
Let the system manage it.
Many, many threads on this, here and elsewhere. I would suggest a search.
Phoenix86
14,644
10
To determine your memory requirements give the PC a workout and check commit charge peak in task manager. That will tell you the peak memory usage of the programs you're running.
RAM+PF must exceed commit charge peak or you will generate an out of memory error. That's how much you "need", so conversly, commit charge peak-RAM=PF *requirements*
Sizing it will not necessarly yield performance benefits. However *if* the system has to manage the size a lot you can end up with a fragemented PF. That will cause system slowness. The answer to that is to either set the PF min=max where the min. is significantly higher than commit charge peak (so you never run out of memory) or let the system manage it, and use a defragmenting program that will defrag the page file.
Real world, with 2GB (edit: running standard "desktop" apps or games) you will not be paging much at all. Because of that, the PF will never need to grow, certianly not on a regular basis that would cause fragments in the PF.
Leave it to system managed, and use a defragmenter that will defrag the PF if it does happen to get fragmented.
