Right after I make a dialup connection, and then run ANY program that accesses the connection (mIRC, Outlook, IE) one of the svchost.exe services eats every bit of cpu going, typically 98%, for about 15 seconds and then all is fine. It doesnt appear to eat cpu when dialling in, but when the first program using the connection loads. It doesnt matter what the program is, just if it is the first one.
I'm certain it never used to do this, but cant think of a setting or installation around the time it started. Ran both Adaware and Spybot several times (with latest updates), and of course ran NAV scans.
I connect using a pci Eicon Diva ISDN TA, rest of specs in sig link. Any idea's whats happening? This is quite annoying as my ISP unmetered net package cuts me off every 2 hours.
