- Feb 15, 2005
- 3
- 0
- 0
I have just put together a system, my first one, it includes
Asus P5AD@-E Premium
P4 540 (3.2Ghz) With Thermaltake Jungle 512 Heatsink
Crucial CT12864AA53E DDR2 PC2-4200 ? CL=4 ? UNBUFFERED ? NON-ECC ? DDR2-533
2 WD 74 gig Raptors (want to run in a raid O)
ATI AIW X600PRO 256M
PLEXTOR|PPX-712SA/SW
Sony DRU 710A Dbl Layer DVD-RW
My problem is.... when I go to install windows XP Pro SP2, it gets to installing devices and just locks up for about 5 min and reboots and the same process happens over and over. This is what I have tried so far.....
Resetting the heat sink (Temperatures are about 48C which I hear is hot) I also tried the stock fan that came w/ the CPU. Temperature never changes.
Tried Silicon image raid drivers (I get a stop error) and ICH6R Intel Raid Driver (Locks up and reboots). I have also tried each hard drive seperate in an IDE congiguration and same symptoms still prevail.
Memory registers in BIOS as well as Video Card.
One more thing, my MOBO also has 4 SATA Connections and 4 SATA RAID connections. I have tried in both of those also the SATA RAID connections are the ones when the stop error occurs.
The MOBO is also supposed to configure voltages automatically, however, if I had to change them manually, I dont know what to set them at. The manual for the mobo does not mention the settings and even though I had purchased a retail CPU, there is no manual included.
Any suggestions would be greatly appreciated, as I am excited to see what this thing can do.
Thanks again, Squiggy774
