ParatoOptimal
I have a dual boot sys with w2k sp4 and xp-pro sp2.
Things started moving slow in XP-Pro SP2 last night.
I rebooted and got ...
Window Title Bar =
Services.exe Entry Point Not Found
Window Message =
The Procedure entry point AssocIsDangerous could not be located in the dyamic link library SHLWAPI.dl
Window Title Bar =
Winlogon.exe Entry Point Not Found
Window Message =
SAME AS ABOVE
Window Title Bar =
lsass.exe Entry Point Not Found
Window Message =
SAME AS ABOVE
I have to RESET to reboot.
I haven't set any GoBack points.
Booting to the last known configuration that worked produces the same results.
Booting to Safe Mode produces the same results.
I can still boot into W2K SP4.
I'm the administrator in W2K SP4.
I can access folders on my XP-Pro SP2 partition.
It serves me well to be able to access those files.
I guess I'll be backing-up those files and reinstalling XP over the old or refreshing it, if that's what they call it.
If that doesn't work, I'll be reformatting that partition and reinstalling.
For some reason, I couldn't get my Ghost working with XP. People online tell me that my version should work.
Window Title Bar =
Window Message =
Window Title Bar =
Window Message =
SAME AS ABOVE
Window Title Bar =
Window Message =
SAME AS ABOVE
