- Dec 24, 2008
- 69
- 0
- 0
Hello,
I just finishing building a brand new E8500 computer. I installed (2) new 640 gig wd drives and a dvd burner. I had initially planned to just take the XP pro hard disk out of my old machine and pop it in this one. It is IDE and I had an ide header on my new motherboard.
I attempted to boot from it and got a "Windows did not Start Normally" message. Well at that point I tried to reload windows xp, but would not give me the option to repair. I figured at this point I would just use partition magic or Hirens Boot CD to try partition, format and reload windows XP pro from scratch.
Do you guys have any better recommendation?
I'm thinking is is probably my best bet.
Can you guys give me a recommendation on how I should partition my (2) 640 gig drives.
I was thinking doing the following..
640gb drive 1
c partition 30 gig for windows
d 300 or so
e 300 or so
640gb drive2
f 320
g 320
Does this sound like a good plan to you? Do you have any recommendations to make this process more painless?
Appreciate your help...
Really want to fire up my new machine so I can start gaming..
Oh and one more question.. Am I ok to stay with windows xp, or do you really notice
a difference by using vista 32 with direct x 10. I don't have vista, so was hoping I would be ok with xp pro.
640gb drive 1
d 300 or so
e 300 or so
640gb drive2
f 320
g 320
