Guys,
I'm relatively new to XP Pro. Just picked up a 160GB Samsung 8MB PATA drive today, to replace the current 40GB 2MB Samsung drive. I hooked it up to secondary HPT372 channel and went into XP Pro and storage management section to set it up. I think the mistake I first made was to try a quick format instead of a full format.
Ghost 2003 seemed to work OK (have primary HD split into two partitions), doing a partition to partition image. However, the 160GB drive wouldn't boot. Tried an XP recovery routine, w/ FIXMBR, but that didn't do it. So, I went back in to XP storage mgmt and set up the disk again, this time doing a full format.
Is there any reason why I can't do a disk to disk image w/ Ghost 2003 from a bootable floppy setup? Or, do I need to do a Ghost install to my primary drive and run Ghost from there? I know that Ghost 2003 "drops out" to a DOS prompt to run, so it seems I should be able to do this from a bootable floppy.
Straighten me out here!
Jeff
Jeff
