- Oct 9, 1999
- 6,185
- 520
- 126
Well, my luck and XP just do not go together. This is now my second try on a completely different/new system at using XP Pro. At first what I was experiencing was a periodic crash, which I first thought might be heat related (usually occured when playing games). Then one time after the crash during reboot, it hung. I managed to get it into safe mode and then tried to reboot again and it came up fine.
Well the periodic crash while gaming occured again later and this time when it started booting, it rebooted itself before fully comming up. It then booted fine. This happened a few more times, and then one time after doing the reboot, it hung again during boot. I got into safe mode again and then tried to boot normally. System hung again during the boot (same exact way as before). Well, I go back into safe mode and do a system restore, reboot. System still hangs. Try an even earlier system restore, reboot, still hangs. Poped in my windows cd, and did a re-install (while keeping existing data, so it basically reloads the core OS file). Upon reboot, system STILL hangs.
So now I am left with formating the OS partition and doing a complete install from scratch... I havn't tried this yet since I wanted to ask here if there is something else I should try. I have up-to-date virus protection (Norton AV), do not use Outlook or IE, and have both spybot and adaware, so I know that the system itself does not have anything on it that shouldn't be there...
The system is the one in my sig if you are looking for hardware details.
