XP-Pro Hubb Hook-Up
KidKasha
I have my system connected with a Linksys Hub. I have 3 computers. I tried connecting the 2 xp-pro ones first. The third is win2k. Here is the eroor message I am getting.?The workgroup is not accessable. You might not have permission to use network resources. Contact the administrator to find out if you have access permission.?
Network path was not found.
How do I get access to get permission, and how do I go about connecting the 2 computers and later add the 3rd win2k. In the past Win2k computers have been connected, now I am unable to connect any.
Assuming that your Hardware is working correctly.
The computers on the Network have to share in order to communicate as necessary.
Important For the purpose of the initial setting, disable all software Firewall (including WinXP native
ICF); disable any active Virus scan or any other utility that might intercept Network Traffic.
If you are not concern about internal security WinXP has a fast simple method of sharing, no user permissions and no passwords.
Windows XP Simple File Sharing
WinXP Pro has an additional more secure method:
Windows XP Professional File Sharing.
XP File Sharing Trouble
