The other night, browsed the web, checked my email....the usual and turned my omputer off for the night. Next morning I had to turn it on, and this message popped up:
"Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM.
You can attempt to repair this file by starting Windows XP Setup using the original Setup floppy disk or CD-ROM.
Select 'r' at the first screen to start repair."
I managed to get my computer running so I can post this message/look for help by installing a fresh copy of XP on my second hard drive.
I have looked on MS Knowledge Base and found a similar problem but it has something to do with installing XP before installing Windows 2000. I tried what they had suggested but it worked to no avail.
So I guess I have two options - 1)Copy over all the information I need to keep and reinstall XP on the hard drive or 2)Find out what is the problem and fix it
One problem:
I have already started to copy over all my information, but everything stored in the C:\Documents and Settings\Clint\" folder is not accessible. I keep getting "Access is Denied". I have quite a few pictures in the My Documents\My Pictures folder I would like to keep. I wish there was a way around this.
Anyone have suggestions? Anyway I can avoid having to completely reinstall everything?
One problem:
