Same Workgroup?Originally posted by: Thawk
I just upgrated my 1st comp and I can't get my old Win 98 SE to see my new XP Pro. Can you give me some things to check? I have them on a lan via a switch. They were networking fine when I unplugged prior to upgrade but now NOTHING!
Thanks!
Same Workgroup?
Can the XP box see Win98 SE box?
You have to enable sharing of a drive or folder on the XP box.
Originally posted by: toy4x4
Define "can't get to the XP Pro". I assume you mean that you have a share on the XP system you are trying to get to on the 98 system. You can ping, that's a good start. Bring up a DOS prompt and type "net view \\{manchine name}" and tell us if you get a response that way.
