I was planning on upgrading to XP sometime but was curious if it will run on my machine. I have a P2-300 I wasn't planning on upgrading till Christmas time. If I say turn off all the fancy stuff will I get a respectable speed?
Agreed, memory is the most important issue here. Your cpu seems to be decent enough for general system operation. If it doesn't have at least 128megs minimum, then forget it.
