XP not being able to read floppy disks
Motero
889
My brother just called me and asked if I knew of any bugs with XP. Apparently his entire computer lab at school and his home PC cannot read any floppy disks if they come from an older PC (Win 98). If you format the disks with Windows XP, it will read fine. Anyone ever heard of this?
johnjkr1
2,124
Nope, I've swapped disks formatted with XP into 98 machines just fine, and the other way around
skychief
219
I'm having just the oppisite problem. It seems that floppy disks created on older machines (95 and 98) will not recognize, or say they aren't formatted, on my XP machine. Interesting problem, I'm curious to see if anybody will respond with a solution.
Motero
889
If I'm reading your post right, skychief, you are having the same problem as me.
OZEE
985
No problems here - I do it all the time. It's probably more a head alignment issue than a 98-vs-XP issue.
Motero
889
It seems he is still having this issue. Anyone else with possiblities? If you put even a blank floppy in the drive it says "Insert floppy" as if its not there. His older XP machines (a year or so) work OK.
Zepper
18,998
I think I heard that some models of hp have had floppy problems - not sure what the issue was, but there is info on the hp and M$ sites. IAC, the 1.44 floppy format for PC hasn't changed since they came out with the IBM PC AT, was that around the mid '80s?
.bh.
Motero
889
These are all built by a local company...and my brother has a Samsung floppy in his pc. Just seems odd to me. I had him do all the updates and check viruses...which didn't help. Only other thing I could try is to put another drive in...but why would 30+ pcs all of a sudden have bad floppies?
GregANDTCH
1,370
I had a problem with my floppy & my cdrw/dvd drives & couldn't read from any of them.
It had something to do with Nero 5.5 & NortonAV 2004.
I had to recover to a previous date & install Nero 6 & NAV again.
It seemed strange that it affected the floppy drive & the CD drives.
I only tried 1 or 2 floppies with it & I don't know what version windows formated them
(or DOS).
BUMP!
Zepper
18,998
Most of the hp mobos have been Asus. IAC, it couldn't hurt to apply the patch just to see what happens.
.bh.
