XP-Mobile and locked PCI/AGP dividers
FBomba6
Recently I installed a new motherboard (Aopen AK77-600 Max based on VIA KT600) and the excellent XP-mobile 2400+ processor (AXMH2400FQQ4C). The unlocked multiplier and adjustable vCore are incredibly cool to play with, and CrystalCPUID PowerNow real-time throttling in Windows is really great!
Unfortunately I have some problems with FSB dividers.
Mobo BIOS does not recognize the CPU ("Unknown CPU type") and sets it at 6 x 100, which is common as far as I read in other posts. I can freely set FSB and multipliers, both within BIOS and Windows. My motherboard never changes PCI/AGP dividers that stay locked at 1/3 and 2/3!
In other words, if I try to set 133 Mhz FSB (factory specifications of XP-M 2400+) the PC does not boot because of PCI bus set at 44 Mhz.
On AK77-600 Max there's a "K7 host clock" jumper which has two possibile values: "auto detect" and "100 Mhz". None changes the board behaviour. My BIOS revision is R1.08 and I have two 512 Mb DDR400 RAM modules; the board uses a Cypress W312-02H clock generator.
Do you know of any hack or trick to solve this situation?
Thank you and bye from Italy
FB6
FBomba6
I think the board should have all the required ratios (it is meant for fast barton CPUs). They just don't kick in when required.
Any hack I could try?
Thnx
FB6
myocardia
9,291
30
Nope, no hacks. Just get yourself an nForce2 chipset motherboard. It's the only chipset to own, if you have a mobile Barton. The Shuttle AN35N is only about $50 at newegg, and overclocks pretty well.
FBomba6
I'm beginning to think that AOpen BIOS determines the PCI/AGP ratio to use using detected FSB of the processor. In other words if it reads 100 FSB it will fix PCI to 1/3 regardless of what FSB I set (which is correctly applied). If I make the board believe that I have a 166 FSB CPU it will fix the ratio at 1/5.
Do you know of any pin modding trick or WPCREdit hack just to change detected FSB of XP-M processor?
Thank you
FB6
