XP Issue -- Mysterious Reboots
FoolishMcNasty
498
I recently installed XP Home on an older Compaq box (5716). The install went very smoothly, yet after using the box for an hour or two, I had a few "Mysterious Reboots". I checked the event viewer and found three error messages:
-The driver detected a controller error on \Device\Harddisk0\D.
-A parity error was detected on \Device\Ide\IdePort0
-AMLI: ACPI BIOS is attempting to read from an illegal IO port address (0x71), which lies in the 0x70 - 0x71 protected address range. This could lead to system instability. Please contact your system vendor for technical assistance.
Any ideas?
ineedsleep
256
I experienced this once... and it was a bios related issue. My mobo manufacturer put out an updated bios to fix the problem... and now i don't experience that ACPI BIOS is attempting to read from an illegal IO port address error.
Check and see if your mobo manufacturer put out a fix. MSI had one and all i had to do was flash the bios. Good luck and i hope it works :)
FoolishMcNasty
498
Thanks for the FAQ, AndyHui (AT FAQ Man). I hope it helps.
Regarding the BIOS update, I can't find any info via Compaq. Anyone have any idea where I can find BIOS updates for old Compaq boxes.
