XP Installation Woes
Saint Nick
17,722
I have been formatting, and re-installing XP for the last two hours on this guys computer and the screen you usually see when you dual-boot comes up with:
Microsoft Windows XP Home
and you have to pick one from the list. im' pretty sure after this install a fourth one will show... how do i get rid of them?
stockjock
4,205
did you delete the partition that you had XP on? If not, try deleting the partition and re-partitioning it and install XP....just an idea
natto fire
7,117
10
If the installation works fine you can disable the startup menu. Go to system properties -> Advanced -> Startup.
edit: that might not be an option in XP home. If not you can edit boot.ini, just erase the other installations from the list.
BadThad
12,100
49
Delete the other OSes in the boot.ini file. Make sure you don't actually have 3 complete installations too. That would be a terrible mess!
Saint Nick
17,722
yeah i got that mess figured out... it wasn't three seperate installations, it was just a messed up boot.ini
tank you guys
