Hi,
i'll try to keep this short(ish), as the long version is dull.
Started off with Windows 2000. Have two hard drives. They were C and D. Was having wireless problems for ages, so split C into C and E, and installed windows xp onto E. Wireless was fine with XP, so the plan was to upgrade win2k on C to winxp, then remove E, thus leaving me with one OS, with all of my settings and programs still intact. The first problem I had was winxp refusing to install as an upgrade to 2000, whinging about not being able to create a temp directory. So I disabled EVERYTHING. All the startup and services stuff that might get in the way, but it still didn't work. So, I tried copying the xp cd to the hard drive, and upgrading from that, which seemed to be working fine, the problem is, the installation freezes at 'installing network' and won't budge any further. It doesn't crash, the 'isn't windows xp great' messages keep cycling and the mouse is still active, but it just doesn't go any further. Tried rebooting and letting it complete another 3 or 4 times, all with the same result. I even tried disabling the onboard network card and removing my PCI wireless card, none of which made any difference. I know windows xp can be installed ok, cos i installed a fresh copy on E, so its just an upgrading problem.
Now, if it were just a matter of reinstalling all of my applications and stuff, i could handle it, but, i've lost my email password, and have no easy way of getting it back. I've tried copying the identity information from C, which recovers the inbox fine, but not the account information. I've tried using Advanced Outlook Express Password Recovery from elcomsoft, but that will only recover from the version of outlook express on the new XP installation on E.
If anyone knows how to either complete the XP upgrade, or tell me another way to recover the password from C, it would be hugely apprieciated. Full system info is below.
Thanks,
James
system info:
athlon xp2000 (at stock)
512mb PC3200
MSI K7N2-L (n-force 2)
WD800JB + Maxtor 40GB
Liteon 40x12x48
Pioneer DVR-105
SB Live! 1024
CNet 311 11b wireless
hauppauge TV card
ASUS GF4 Ti4200
Thanks,
James
system info:
512mb PC3200
Liteon 40x12x48
Pioneer DVR-105
SB Live! 1024
hauppauge TV card
ASUS GF4 Ti4200
