well i bought XP yesterday, and ever since 7 last night i have been trying to install it. First i tried to upgrade 98SE but everytime it checked disks for errors in the setup program, sure enough it found one it couldn't fix... so i boot 98SE and ran scandisk, it finds the error, fixes it and i try upgrading again... same thing! :| Now i am not too happy so i start deleting everything... Then i format (converted to NTFS) thinking "haha you can't corrupt files now you POS." well i was right and it copied files to the first restart, then it boots up shows splash screen (YAY) then BSOD!!?!! already? now it corrupted files after then install... this time (done it a few times, same result different files) it says there is a problem with "atapi.sys" and it stopped to protect my computer from damage. So i think maybe i can disable that... NOPE currupted registry when i tried using repair command prompt....
Anyone know whats going on? bad cd? stupid operator? need to pull out all cards first?
EDIT: guess you want hardware specs...
ABIT kt7a-raid (recent bios)]
Ati AIW radeon 32mb ddr
Creative audigy
1.2ghz tbird
dlink 530tx
2x maxtor 30.7gig in RAID 0
teac 16x10x40x
pioneer 106s 16x DVD
crucial 2x256mb
tell me what else?
-Trek
Creative audigy
1.2ghz tbird
dlink 530tx
teac 16x10x40x
crucial 2x256mb
tell me what else?
-Trek
