XP boots, but no explorer.exe, and can't manually run exe's...PLEASE HELP
EvilYoda
21,198
9
So yeah, I was trying to run the new Need for Speed 6 demo and it froze on me (my roommate had already installed the file too, so I don't think it's a virus, and he scanned the file)...so I manually restarted the computer, and upon restart, the system (after logging in, and quite a delay) gave me an error about the registry (couldn't find parts of it and had to "pull" from somewhere...) but it said it was successful so I paid it no heed. But after that, nothing commenced, so I opened task manager, and noted that all services were running other than explorer (or at least most). So I tried to "run program" explorer, and it says that there is no association with that file type and to do something about it in control panel (of which, I can't get to).
I can use all bat and com commands, such as command, but not cmd. I still have network capability, since I can telnet into my university account and check my email still. Other exe's are present when I check running processes.
Any suggestions? I've tried a few things already...check the reg -> software->microsoft->windowsNT->winlogon-> shell is = explorer.exe
If nothing else, I'll just try copying my roommate's explorer.exe over, and if that doesn't work, proceed with reinstalling. But I REALLY DON'T WANT TO.
HEEEEEEEELP.
EvilYoda
21,198
9
The newest updates are that I can still browse through my files when I open "run programs", and I found out that I can open an avi or pdf file, and that will open the respective program! AVI says DirectShow isn't installed correctly, but the PDF was fine. MP3s are not recognized however. ANy ideas?
Please help guys.
Fixxors
101
If you have antivirus software you may wanna boot from the disk and see if you can find anything, sounds like you might have good ole klez on yer system. If its not a virus it sounds like a reinstall is in order, and you may wanna check that hard drive for errors/bad sectors...
