XP-90 and Neo2 Installation
Tweakin
When mounting the xp-90 or 120 on a Neo2, are the pipes on the AGP side or the Memory side?
This makes a difference with heat pipes as they need to be vertical for best operation.
XP90 fits well..the XP120 may require you to bend a capacitor...
the pipes are on the agp side...the HS hans over the ram and you can still mount the ram without issues..except corsair with LED
Perfect...I can't use my Zalman any longer as it interferes with my moded ATI...and the stock is just not enough for me.
