I need help with making a floopy with the correct sata drivers. I tried promise fastTrak 378 beta
and either did it wrong or have the wrong drivers. I have an MSI K8T NEO FIS2R.
I'm trying to do a new instal on a wd 80gig sata drive. Any help would be great.
I couldn't find drivers for XP-64 on either MSI's or Promise's sites. Promise doesn't even list anything by chipset. 😕 Did you check the XP-64 driver thread?
