XP 2600 cooling
imported_Jack
Current setup:
XP 2600, Cooler Master DP5-6I31C (antec's silver therm compound), MSI K7N, 512 ddr 2700 kingston, matrox mil 450 dual head, enermax 350, 2 80mm exhaust fans, 1 80mm side fan, 1 120mm intake (antec)
I strictly use this pc for realtime business app's that keep the proc @ 40-70% on ave, and a couple times/day it will stay at 100% for 20-25 min when I'm crunching some #'s in excel. When I first built it I had a volcano 9 that I wasn't too impressed with. Found I got better cpu cooling from the cooler master and it was much quieter.
On ave the cpu is 5-10C abv ambient. Idle is ~ 37C, max load as high as 48/49C depending on the weather. My concern is with summer coming I feel I need to be more aggressive with cpu cooling. I'm also considering putting a 120mm exhaust fan in the top of the case.
CPU coolers I'm looking at:
SLK 900A w/tornado w/fan controller. I feel I won't always need it blowing at 4800rpm.
or
Volcano 12, but adding TT's A1442 ducting.
I haven't done any overclocking on this proc, not even sure what I can get out of it.
Do you think the additional exhaust fan will be enough or should I go with a new HS as well?
Any replies much appreciated
Unless you anticipate your CPU temps going higher than 65C during the summer, I'd save your money. You aren't overclocking, so stability at higher temps is a nonissue unless you see them higher than 70C.
Although it's nice to keep your CPU running cool, there is no difference performance and stability wise between a stock XP2600 at 50C and one at 65C. You also mentioned that you only stress your CPU a few times a day for relatively short amounts of time; yet another reason not to be concerned about your CPU temps.
