- Jan 9, 2001
- 704
- 0
- 0
I have been having some strange issues with my system, and I'm at a loss as to what is wrong. Here are the specs.
T-bred B, model AXDA2100DUT3C and stepping AIUHB0302UPCW running @ 2068mhz (166x12.5@1.70V). The processor will run @ 2167mhz same voltage fine, but i clocked it down to see if that had any effect on my problem.
Epox 8DRA+ with bios dated 1/29/03.
512 megs of DDR2100 (Crucial and a generic) both at 6-2-2-2.5 @ 166mhz
GF4 ti4200 @ stock speeds
IBM 40gig ATA100 7200prm HD
Hi-val (aka Lite-on) 48x16x48 cdrw
Mit floppy
350 watt PS generic
WinXP service pack1
Nvidia 2.03 drivers
I have a global win heatsink with an 80mm fan taht came wiht it, generic 80mm case fan, Vantec 60mm stealth exhaust fan, and an Evermax(i believe) 80 mm temp sensing fan in the side window.
I seem to be getting some strange errors, random lockups when running Folding @home and other programs and I cant seemt o figure out why. I have run Memtest86 several times and the ram checks out fine. According to the Epox USDM, the cpu is running @ 50C under 100% load, system is running @ 21C. V-core seems to flux between 1.696-1.71V, 5V reads 4.892V and 12 volt is 12.16V. The cpu seems to run fine, played all the usual games with no lockups or errors, only seem to get them when doing normal internet use etc etc. They seems to have gotten a little better, but I was online this morning and the computer was running fine then randomly turned off and didnt want to reboot for about a minute or so. I am leaning toward a PS problem, but the voltage seems to be ok? If anyone has any ideas, please let me know. Also, I ran the ram at the normal 133mhz speeds and it didnt seem to make a difference, so I have ruled that out for now.
Thanks,
Josh
Mit floppy
350 watt PS generic
WinXP service pack1
Nvidia 2.03 drivers
Thanks,
Josh
